Boas, necessito de ajuda.
AGRADEÇO A QUEM POSSA DAR INFORMAÇÃO COMO EMPARELHAR UMA NOVA CENTRALINA NUM TD5 COM A NANOCOM.
Adquiri a NANOCOM, mas não sei como emparelhar uma nova centralina.
Ou informar algum LINK no YOUTUBE demostrativo passo a passo.
NANOCOM
- Joao Pinto
- Gil Craveiro
Re: NANOCOM
Aqui vai:
HOW TO REPLACE THE ECU
1) Read the injectors codes directly from the injector or if it is possible from the old ECU by means of
the READ SETTING function
2) Verify if the accelerator type is 2 or 3 track
3) Install the new or used ECU
4) Read the injectors codes from the ECU by means of the READ SETTING function, modify them, set
the accelerator type and write these new data with WRITE SETTING function.
5) Perform the SECURITY CODE LEARN to synchronize the alarm with the new ECU
6) Write the appropriate map with the WRITE MAP function. You can generate the correct map file
with the NANOCOM MAP WIZARD application included. The maps are grouped according to this
information: vehicle type, ecu PART NUMBER and world region
- Joao Pinto
Re: NANOCOM
Obrigado por a ajuda
