Painel de instrumentos Series IIA
Rui Caldeira
Land Rover: Series IIA
Series III
Stage one
Defender 110
Sócio LCP: 20
Mensagem por Rui Caldeira »
Viva,
Alguem sabe se o painel de instrumentos de um Serie IIA deve ser pintado á cor da carroçaria ou a preto?
Os que vou vendo quer ao vivo, quer na net, aparecem das duas formas...
Obrigado,
Rui Caldeira
JBorges
Land Rover: Série 3 88" 1981
Sócio LCP: 2253
Re: Painel de instrumentos Series IIA
Mensagem por JBorges »
Qual é o ano??
- Early LAND ROVER Series IIA(1962-1967): Headlamps are on the breakfast. Tall sills under the doors, about four inches in height. Steering tie rods connect under the axles. Dash is painted body colour. Separate windscreen wiper motors. Mirrors on the wings. To many, this is the "Classic" Land-Rover.
Note: There is at least one Canadian Early IIA with factory headlamps in the wings, but this is extremely rare.
- Transitional IIA LAND ROVER(1968/9?) :(a few thousand built): Headlamps on the wings, but surface mounted giving a "bugeye" look. Grille was an inverted T, but the wide portion is nearly the height of the Centrex portion. Rest of details similar to the Late IIA.
- Late Series IIA LAND ROVER(1968/9-1971): Headlamps are on the wings, but the radiator panel is covered by a metal galvanized grill (after 1969). The later IIA had a single, single speed, windshield motor (after 1967). The instrument panel is painted black, and not body co lour as on earlier vehicles. The sill panels are narrower, being approximately two inches tall, unlike the much wider panels on the earlier IIA's. (1969-71 door latches changed, changed again for III). Mirrors on the top door hinge.
Rui Caldeira
Series III
Stage one
Defender 110
Sócio LCP: 20
Olá!
Excelente! Está explicado porque os via das duas formas:)
O series é de 1971. Logo, deverá ser preto .
Obrigado!
Rui Caldeira
NorMarques
Land Rover: Serie IIA 1968
Mensagem por NorMarques »
Boa Noite,
Retomando este tópico existe alguma referencia de cor para o preto do painel, bem como as outras partes pretas dos series?
Norberto
TAG
RR Classic 96
Mensagem por TAG »
Não sei, provavelmente haverá. Já vi o painel em preto mate e em brilhante.
O meu, que estava original, era brilhante...ligeiramente.
